Tire sizes on 1989 3.2 question
I just bought a '89 3.2 cabriolet which is in need of tires. It appears as though the rear wheel is wider than usual, perhaps a turbo wheel? I thought I read the 89s came with standard 8" fuchs in the rear.
I don't think the size that tirerack.com is telling me is correct.
Can someone tell me the correct tire size, front and rear for an 89 3.2?
There is little visual difference between the 8x16 ET10.6 stock rear wheel and the 9x16 ET15 930 version. If you aren't an expert pull a rear wheel and look at the back of the spokes, all the info is there.
Actually, the difference between an 8x16 and a 9x16 is easy to see. The base of the lug nuts will be flush with the wheel on 8" wheels, but look like they are countersunk on 9 inchers. 9" wheels will usually be fitted with 245/45 tires.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Yep, roger that... 9" rear with 245/45/16 that's what I have on my 88 coupe. That size is getting hard to find.
Dan.
