Suspension Question
1982 911 SC with 78K miles
Question: I can grab either front tire at 3 and 9 oclock and while rotating the tire see the steering wheel rotate about +/- 15 degrees. Is this normal?
The car is on jack stands supporting under the front bearings of the A-Arm.
RL Technical Advisor
If your car is supported on jack stands....
When you hold the tire and physically move it as it would be if turning the car...the steering wheel will follow your movement. If you move the steering wheel the tires turn....if you turn the tires the steering wheel turns. You are making mechanical movement through the steering rack from the tire to the steering wheel....get it? I would be extremely concerned if the steering wheel did NOT move when you moved the tire as you are descibing. Now...if a helper holds the steering wheel and you still get some slop or movement in the tire you have shot suspension parts....get to a mechanic. 911_pilot
