Condensation on gauge face
2nd Gear
I recently upgraded the temp. gauge to the numbered unit on my 89 Carerra. Problem now is when I start driving the gauge face get a little cloudy with condensation. It goes away after 20 minutes or so.
I must admit that the change was made in the late fall (Mid Ohio Region) and I have driven less than 1,100 miles since then.
Any suggestions or should I just wait for warmer weather?
John
John
The condensation is due to a moisture trap between the gauge face and car. The trick to removing the condensation is to have the temperature the same inside and outside the gauge. Remove the gauge and drill a small hole (1/8") from the bottom side up into the sealed instrument area. You can use two holes for better results. This will allow the air to flow into the gauge and maintain the same temperature.
It wouldn't hurt to take something like a hairdryer and blow warm air into the gauge while it's out. Completely dry the gauge so there is no moisture in it.
Hope this helps, never had to do it; but read about it on a previous thread at Pel-BBS.
