'73.5 T Fog Lights
I am looking for a set of correct fog lamps that fit into the lower front valance below the bumper for my 73.5T. Can someone advise as to the Hella model number for these lamps?
Does anyone have a pair they want to part with?
Thanx
Tim
Thanx
Tim
What valance do you have? If it's the S one which was common on the 73.5 T, then there are no lamps for it. On those cars, they put the ones that went through the grilles - you'd need the special grilles with the slats cut, the D shaped bracket and the lights. I don't know if the non-S valance cars did the same or did the Hella 134?s in the openings.
