Valve Adjustments...how often ?
Hi~
It has been about 10,000 miles since my 911 had a valve adjustment, the valves sound ok, but it is due for an oil change, so I was wondering if I should go ahead & do it.
How often do you adjust your valves ???
thanks,
Chris
82 911sc
37,000 mi
thanks,
Chris
82 911sc
37,000 mi
Chris,
I adjust my valves annually; I adjust them in conjunction with an oil and filter change.
You should be careful and not totally rely on their sound to determine if adjustment is required. Loose valves will make noise, but tight valves will not.
Regards, Bruce
'84 911 carrera
'77 911S (Euro)
Regards, Bruce
'84 911 carrera
'77 911S (Euro)
