Jack at the track?
What do you use to jack up your car at the track? A regular floor jack would be nice, but lugging one to the track is a hassle, although I see that some folks do that. The factory jack is a bit wimpy and slow. Any middle ground here?
Will
Will
Go to your FLAPS and buy one of the 3 ton floor jacks that comes in a plasitic carrying case. I think I paid about $50 for mine? Also - get a "jack pad" from a Rennlist Sponsor (blatent endorsement
- and these "pads" fit into the jacking tubes on the lower rockers) so you can change both wheels on a side at the same time.. However - look carefully at the "pad" on the floor jack - and be sure it is large enough to fit over the jack point on the underside of the car. Finally - invest in a hockey puck to put between the jack pad and the car, if necessary...
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
