996 starting troubles
I am having trouble re-starting my 1999 996 after it heats up(200), its starts to turn over but it seems like there is almost a hydraulic lock and it wont start. It starts fine cold, and will start fine after cooling down as well. The battery is less than a year old, and the alternator is charging fine.
Has anyone else experienced this? Any help would be appreciated.
Thanks,
Brett
Thanks,
Brett
Hi Brett and welcolm to Rennlist.
You are actually in the "Oil/Air cooled Discussion Area" If you go to the main forum menu you will find a 996 forum.
I'm sure those boys will be able to help you over there.
good luck.
good luck.
