adjust cluth cable or do short shift first?
adjust cluth cable or do short shift first? I am planning to do both. I have all the parts for the SS, but which should I do first.
'84 911
thanks
'84 911
thanks
The short shift will make shifting worse if the clutch needs adjusting (amplifies anything wrong) Do the clutch cable, get everything right then do the short shifter. The clutch cable is 15/20 min. The SS is a couple hours.
Kevin
Kevin
