911 Forum 1964-1989
Torn Sway Bar Mount
Old Jan 3, 2002 | 06:08 PM
Jgordon's Avatar
Jgordon
Unhappy Torn Sway Bar Mount
I was hoping someone could shed some light on this: I purchased my car in october. It is an 89 carrera, and it had 43,000 miles on it at the time, in absolutely mint condition. Recently, I appear to have torn/broken the right rear swaybar mount. My mechanic says that this happens from time to time, but it doesn't seem like it should.
Is this an indication of hard driving or abuse? Does this "happen from time to time?"
Any insight you guys could offer would be appreciated.
Thanks.
Old Jan 3, 2002 | 06:26 PM
Kurt V's Avatar
Kurt V
Post
It happens a lot! Just take it to a competent welding shop and have them weld the mount back in place.
Old Jan 3, 2002 | 09:14 PM
richard glickel's Avatar
richard glickel
Post
JG,
Unfortunately, it does tend to happen. There is a stronger aftermarket swaybar mount that you can purchase. I'm not sure if its a weltmeister part, but I seem to remember seeing the upgraded mount in the Performance catalog.
Richard
'87 Carrera 3.6L
Old Jan 3, 2002 | 10:30 PM
Thom Fitzpatrick's Avatar
Thom Fitzpatrick
Post
I just went thru this last week!
x
Old Jan 3, 2002 | 11:22 PM
James Achard's Avatar
James Achard
Post
This happens frequently on these cars especially if you are running larger than stock tires on them. I will try to find those aftermarket ones for you. If you DE the car this is the way to go. My mechanic re-welded mine with a gusset on it so it would last a bit longer.
James
Old Jan 4, 2002 | 09:44 AM
Jgordon's Avatar
Jgordon
Post
d'oh! Oh well. Do you think it's likely enough to happen to the other side that I should see about replacing them both at the same time?
Nice pic, Thom. That's about what mine looked like when I got under there.
Thanks again.
Old Jan 4, 2002 | 10:50 AM
Geoffrey's Avatar
Geoffrey
Post
Thom,
It looks like you are running an aftermarket sway bar, perhaps a TRG (The Racers Group) bar. Be careful to make sure you have it adjusted so that it does not cause the car to go into a bind which will rip the mounts right off the car.
Regards
Old Jan 4, 2002 | 11:02 AM
Carrera51's Avatar
Carrera51
Post
J:
Been there done that. I put a set of Charlie Bars (very nicely made by the way) and busted the driver's side mount. I decided to replace both mounts with the updated ones (from Porsche) that have an extra reinforcement. My mechanic also made an extra reinforcement to go with it. He said that this happens on the pre 964 911s. The mounts have been in place for about 18 months. Many DEs and 4 races later and the mounts are still holding.
Old Jan 5, 2002 | 01:42 PM
Cary E's Avatar
Cary E
Post
I'm going to get mine from Steve Weiner.
He'll get you some that are proven.
But you'll need/have to weld them in. So even the best bracket will be worthless without a great, clean weld job.
Old Jan 6, 2002 | 12:54 AM
Rod Walter's Avatar
Rod Walter
5th Gear
Post
I replaced the right mount on my car, too. I have the stock sway bar and apparently an attempt had been made by the prior owner to repair the original mount but it didn't hold. The updated Porsche part, # 911.501.983.00, is reinforced compared to the original. FWIW, I only replaced the right side since the left appeared to be OK and is still holding out well.
As the others have said, this is a very common job.
Old Jan 8, 2002 | 07:03 PM
Jgordon's Avatar
Jgordon
Post
My mechanic replaced the right side yseterday. While doing that, he noticed two things:
The left side was showing some stress.
I was calling like a worried mother.
He replaced both sides, with the reinforced pieces. I'm picking it up later this week.
Thanks for all the info, much appreciated.
