D90's on a 911 SC?
Will the D90's (the standard wheels for early 964) fit the 911 SC? What spacers do I need? (I know thte ET is different)
I already have a set of D90's.
General rule of thumb...
Post 89 911's 52-55mm offset will require spacers
78-89 are low 20MM offset
What you need are a set of ADAPTORS, 1in in front 1.5 in rear
Hope that helps...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I have a set of H&Rs is good condition thats I just removed from my car, all aluminum with their own studs, asking around 225 for the set, they are hubcentric BTW.
Hope that helps...
