Weber stumble-any advice
I have a 911SC with Webers, headers, MSD ignition and 964 cams. Venturis are 36mm, F3 emulsion tubes, 160 main jets, 175 air correction jets, 65 idle jets. I am running the PMO pressure regulator and it's set for 3.5 psi. The jetting, fuel pressure, carb cleanliness, plugs, wires, rotor and timing are all good. The only problem is that at very small throttle openings, like just above idle or while cruising under light load, the car stumbles and sputters and the a/f ratio gauge I have shows really lean. Applying slightly more throttle clears up the sputter completely. What could cause this? What is the fix?
If it only happens at throttle tip-in, I would check the accelerator pump circuit. You can do this by taking a small vial (I used a small dropper from a medicine bottle and sealed the end with a lighter) and attaching a wire to it. Lower the vial down into the venturi and slide it under the accelerator pump jet. With the engine off, pump the throttle to WOT twice and measure the output. Do this for all six venturis and ensure they are all about the same. Spec is .6 to 1.0cc I think.
If they are uneven by more than .2cc, you may have a clogged or leaking jet (unlikely), broken pump diaphragm (definitely possible if old rebuild), or failed check valve in the float bowl.
Good luck!
Good luck!
No, the problem is not at tip-in, it's under steady state but very small throttle openings only. Example, driving 60 mph down a level highway with no headwind and the stumbling will go on and on for miles. If going up a hill or driving a little faster or in a headwind which need a little more throttle, the problem does not occur.
Originally Posted by 911pcars
Fuel level in carbs? Have you checked?
Sherwood
Sherwood
Given my recent postings trying to get my CIS to work, which now does, and the comments I received that the solution was to go carbs, I feel I have to return the favor: Dump the carbs and go CIS!
Originally Posted by loosecannon
Yes, fuel level and synchronization between carbs and even air/fuel ratio with a wideband have all been done. I took Steve Weiners advice and put in 60 idle jets and it seems to have cured the problem, which is strange because my narrow band O2 sensor was showing a lean condition when the car sputtered. Oh well, whatever the case, it has great throttle response, lots of power and I couldn't get it to sputter no matter what I did-thanks Steve
Enjoy.
BTW, Steve W is the best!
Originally Posted by VNTGSPD
Glad its solved! If my head is on straight, everything you are saying is correct. By reducing the idle jet from 65 to 60, you are reducting the amount of air entering the circuit and therefore richening the mixture coming out of the circuit. Therefore, the lean condition registering on the O2 sensor gets richened up and voila, runs great!
Enjoy.
Enjoy.
