911 Forum 1964-1989
Lightest wheels?
Old Jun 24, 2007 | 07:12 PM
LaughaC's Avatar
LaughaC
Default Lightest wheels?
Does anybody know how much my 6"x16" Fuchs weigh and what other wheels may be lighter for the track?
I also have a set of D90s to consider but with tires on them it's hard to guage how much of the weight is just the rim.
Old Jun 25, 2007 | 04:01 AM
earlyapex's Avatar
earlyapex
What sizes are you looking at?
Old Jun 25, 2007 | 09:07 AM
AJ88CAB's Avatar
AJ88CAB
This should help.......
Wheel Specs
More Wheel Specs
Old Jun 25, 2007 | 08:19 PM
911S3.6's Avatar
911S3.6
Amazingly, fuchs prove to be the lightest wheels, unfortunately not available in 17". The 16x7, 16x8 weigh around 16-17 lbs. When shopping for track wheels and looking to keep unsprung corner weight down, Fikse came out the lightest around 17 lbs. They are 3 pc forged. I've heard Forgeline are also light. Stay away from the cast wheels they can weigh on the line of 26 lbs ...
///Nick
Old Jun 25, 2007 | 09:48 PM
LaughaC's Avatar
LaughaC
Thanks for the great charts and comments. It looks like I should stick with my 16"x6" Fuchs, and maybe even use my 14"x5.5" Fuchs for autocross or winter tires.
Old Jun 25, 2007 | 11:25 PM
g-50cab's Avatar
g-50cab
My BBS wheels (RS) are between 1.5 to 2 lbs less than my same size fuchs 8x16 and 9x16.
Old Jun 26, 2007 | 12:00 AM
DARISC's Avatar
DARISC
Jeremy, I just pm'd you
Old Jun 26, 2007 | 01:39 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
It's very hard to find anything lighter or stronger than the Fuchs,--and the reason why they are so popular. They are a terrific wheel. Being forged, they will bend before they break and are significantly lighter than any cast equivalent.
Old Jun 26, 2007 | 05:07 PM
earlyapex's Avatar
earlyapex
Fuchs are great tires. I do worry about 30 year old wheels running DOT-R tires.
Old Jun 26, 2007 | 05:27 PM
DARISC's Avatar
DARISC
Ohboyoboy! Whar kin I git me some them Fuchs tars? I betchum dey be very light!
Old Jun 26, 2007 | 07:34 PM
911S3.6's Avatar
911S3.6
+1 Eric.
Save the fuchs for street use and appearance and find some lightweight forged wheels for track, preferably 17".
///Nick
Old Jun 26, 2007 | 08:02 PM
Slantnose!'s Avatar
Slantnose!
Originally Posted by 911S3.6
+1 Eric.
///Nick
...very true & good advice.
Old Jun 26, 2007 | 11:58 PM
earlyapex's Avatar
earlyapex
Our 18's!
I have two sets of Jongbloed wheels with custom offsets on my flaired SC.
Old Jun 29, 2007 | 01:36 PM
BlackPearl's Avatar
BlackPearl
+1 Eric.
///Nick
Good idea. However, many of the competitors in San Diego, myself included, use 15" fuchs for the track. Yes ... I said 15". They will shorten your gear-ratios with a higher rev's-per-mile wheel ratio than 16's or 17's, and you can take advantage of the extra little "umph" of torque from the shorter roll-out. Also, they lower the car a tad more, allowing for tighter handling on the smaller, tighter A-X tracks. They are also a tad lighter than the 16's. If you run 17's they'll give you grip galore, but you may notice a taller gearing effect ... this may equate to a slower exit from the corners.
I run 15" X 8" Fuchs. They fill the fenders, give the car a big footprint and lower profile, and because of their apparent height, don't rub. The only problem I have with them is occasionally scraping the chin spoiler getting to the track.
Currently 3 SC's, and 3 Carerra's (1980 series Carrera's) are running this configuration in San Diego, with class-winning times.
Just my 2-cents.
Old Jul 1, 2007 | 06:12 AM
rnln's Avatar
rnln
Eric,
can you post pics of your 18" on your 911?
Thanks.
