911 Forum 1964-1989
Reliability of 3.2?
Old 06-08-2007 | 12:18 PM
Gary R.'s Avatar
Gary R.
Originally Posted by murphyslaw1978
Good points, Keith. I almost forgot something important: The PPI can check for excessive valve guide wear, so have it done on your engine when shopping around. Basically, the mechanic just pops the valve cover off and checks tolerances.
Yep, or in the case of the one I have for sale just stand behind it when she 1st starts after sitting a bit. EASY to know when the guides are done!
Old 06-08-2007 | 12:31 PM
joey c's Avatar
joey c
i bought my 87 3.2 2 years ago..NO PPI..crazy yes..BUT i am glad i did not get the ppi..the 1st year i put 5k into the car..if i knew this was going to be the case ,i never would have bought it..NOW,i have an amazing car..i knew the sunroof was not working,700 bucks to fix,major service and and new brakes with caliper rebuild,new alternator(500)..axel boots,wheel bearings,i bought a set of fuchs here on rennlist(600)....i have a car that has no leaks,pulls strong and is a blast to drive..no problems at all..i have owned 5 porsches,mostly new ones,and this is the best one i have owned,and yes i have owned a 993..j
Old 06-09-2007 | 05:12 PM
Ed Burdell's Avatar
Ed Burdell
Originally Posted by joey c
...i have owned 5 porsches,mostly new ones,and this is the best one i have owned,and yes i have owned a 993..j
I'm another 993 owner lurking around here, reading about 3.2's...I'll never sell the 993, but I sure am intrigued about adding an older one to the stable!
Old 06-11-2007 | 11:52 AM
rappalm's Avatar
rappalm
Joey c, what didn't you like about the 993?
Mike Rappa
87 Carrera Coupe
Old 06-12-2007 | 08:38 PM
RacingBeat's Avatar
RacingBeat
my ideal is a silver 993 coupe to go with my 84 targa.......oh and a honking 928 too........and, well maybe even the truckster S for unavoidable family hauling
Old 06-30-2007 | 11:24 AM
Gregg's Avatar
Gregg
I have a 3.2 with 80k, just had the valve cover gaskets replaced to fix an oil leak, brakes all around, cat bypass and sport muffler(really like that) and found out that a couple valve guides are leaking, but decided not to do anything now because the car runs so well. Guess i'll just keep an eye on it and drive it.
Old 06-30-2007 | 02:07 PM
Giantviper's Avatar
Giantviper
My daqd has had is 1986 3.2 since new with no Problems. I think it is an awsome car. Also,once thing to consider with that engine is that Porsche still uses the same basic design for theire race engines and turbos. THe 997 GT3 still uses the same basic Block as the 3.2 just with water cooled heads and same for the 997 turbo. Obviously there have been some technoligy updates and the displacement has been changed but when broken down the engine has the same basic design as the olod 3.2 from the '80's. I think that says something about these engines.
Old 06-30-2007 | 08:18 PM
joey c's Avatar
joey c
i loved the 993 and want one in the future..i like the overall rawnss of the 3,2.the 993 was faster and newer but,but 3.2 is nice and raw..i will wait and get a nice 993 in the future..
Old 06-30-2007 | 09:51 PM
blake's Avatar
blake
Originally Posted by Giantviper
...one thing to consider with that engine is that Porsche still uses the same basic design for theire race engines and turbos. THe 997 GT3 still uses the same basic Block as the 3.2 just with water cooled heads and same for the 997 turbo.
Very true. The 996 GT2/GT3/Turbo all share the same "core" engine, as does the 997 equivalents... Many people on Rennlist are quite leary of the M96 engine due to the oil starvation issue if tracked... For that reason, I would own a 996 as a daily driver, but not as a car to push...
From all that I have heard, the 3.2 AND 3.0 engines are bulletproof. Great thread. Looks like the minimal number of "hang ups" have been cited...
-B
