Grease Cap Removal and Brake Pad Help
I'm in the middle of checking my front wheel bearings and changing brake pads.
1. How do you pry off the grease caps. I can't seem to figure it out.
2. My old brake pads are really stuck in the caliper. Any tricks to getting them out?
take the calipers off of the rotors....tap the brake pedal.
you might put something between the pads to stop the pistons from popping out
One of mine I was able to work off with a very large pair of channel locks. The other I went at with a hammer and masonry chisel set on the indentation in the cap while hammering from inside the wheel well. Rotated the hub giving a couple of firm taps at each stop. The cover wasn't too pretty when I got it off, but you don't see it anyway.
The tool described in the pelicanparts.com thread is a nice idea.
Brett
Brett
Everybody likes to make it so difficult. Just use 2 hammers. The claw of one on the 'ridge' & tap the 'hitting' surface with the other. Work your way slowly around.
Ian
Ian
I use a small ball-peen hammer, tap lightly and rotate 180 degrees after each tap. Never have a problem and caps still look OK. A new tool is fine, but this way has worked for me for over 50 years.
Lifetime Member
Lifetime Member
Taking off on what Spider suggested -- I have used a similar technique since the 60's when I worked in a shop rebuilding VWs. Use 6" brass rod as a drift, tap it, rotate, tap it... No evidence of removal.
The way to check the bearings requires removing the dust cover. Remove dust cover and check if you can move the large flat washer with the flat of a screw driver.
Lifetime Member
Lifetime Member
I use a piece of 2x4 and a hammer. I wouldn't recommend using a steel hammer against the cap directly - too easy to hit one of your wheel studs and much the threads.
-Chris
-Chris
