911 Forum 1964-1989
valve adjustment - loose or tight
Old Aug 3, 2002 | 11:36 AM
88cab911's Avatar
88cab911
5th Gear
Post valve adjustment - loose or tight
After recently adjusting my valves, it sounds as though I may be a bit loose on one or two as I hear them now when before I did not. I checked and re-checked twice but I'm loose on a couple. If I don't go back in imediately to readjust will I hert anything being loose. To tight would cause burnt valves but what does loose valves do other than detract a little from HP ?? I have a DE to run at Road Atlanta the end of the month and I don't want to do them again before that event.
Old Aug 3, 2002 | 03:42 PM
A Quiet Boom's Avatar
A Quiet Boom
Post
If they are really loose the rockers hammer the valves pretty hard and cause excess cam wear. If they aren't to loud I think you could run the car for a short while, after all we're not talking about super high lft cams and lots of spring pressure like on a race setup. I've seen plenty of cars with manually adjusted valves being run long after they were due for adjustment.
