Has anyone had this problem with their turn signal combination switch?
The car is running great. I have sorted out the major issues and have been using it as my daily driver. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I fixed the turn signal issue with little difficulty. The inserts that attach the horn pad and springs to the wheel were worn, so I special ordered them from Porsche. Thanks to those who gave great advice on bending the contact strips.
My next project now has to be my A/C, which only blows ambient temperature air. It must have a leak. The immediate need became apparent when I had to drive to Palm Springs for business, a regular monthly appointment.
Are you going to the Porsche Parade? I wish that you could pay a daily fee, since I only to attend a 1 days event.
Yeah, I'll be in the Concours. Probably won't be a strong showing for me though. I've got some other big projects going on right now, and I just don't have the time to prep the car to a high standard. Regardless, I'm looking forward to it.
Good luck with the AC. I need to tackle that one some day, too.
Brett
Poseur
This is an age-old problem. Figure on replacing these every 65,000 miles. To do the replacement you need to remove the steering wheel (easy to do), and then with a smaller standard screwdriver, remove the black plastic steering column covers (top and bottom) and then release the turn indicator assembly and then fish out the quik connect socket. Installation is the reverse. It's very easy to do, thankfully. This is nearly as well known a problem with 911s of that era as chain tensioners.
Just do it soon,--it will drive you nuts, particularly at night as everyone will think you're flashing them all the time.
I installed the Flat6Turbo headlight relay this morning on my '84 - took 45 minutes because I spent some time hiding the relays and wiring. Hopefully that will extend the life of the switch for a long time.
Steve
84 Carrera Targa
00 M5
02 G500
Steve
84 Carrera Targa
00 M5
02 G500
