The rebuild begins....
"I took about 60 pics of the injection setup to make sure it goes back together as it should."
What? The 911 3.2 system is a very simple system requiring at most about 5 minutes effort
to reconnect all the electricals.
Why don't you go away and bash Steve Wong's chips on Pelican or something and stay off my thread if you have nothing to contribute?
![w_attention](https://rennlist.com/forums/graemlins/attention_whore.gif)
Originally Posted by SeattlePorsche
Ed,
Awesome! Where did you go to college? I went to UT. Used to visit my sister at SMU all the time. Miss the tex-mex food.
Location: Waiting for the pass behind you, or Sebastopol, CA
Impressively fast work, Ed !
I had a similarly expensive 'money shift' but also snapped the rockers last time around. Looks like you were lucky to just ding the crowns a tad.
Clever way to check for bent valves while in the head! Once removed, spinning them in a cordless drill will also show a wobble.
I recently had my engine out (as a firs timer) and also did the 60-plus pllus plus pictures. Eventually I moved my laptop into the garage for re-assembly given how much I had to reference. I disassembled my 3.2 intake for powder coating and REALLY used the photos then.
Best of luck with your project!
Thanks Glenn.
I'm pretty much resigned to the fact that all of my exhaust valves will be replaced. With 130K on the sodium valves, the odds are it is time. I've got them figured into the budget.
Originally Posted by Ed Hughes
.... all of my exhaust valves will be replaced.
Have you thought of machining out a little more room in the pistons for the valves to play? I regret not looking into this a little more as it might be good insurance. What do you think?
Cheers -
Team Owner
Wow look like I missed a few posts as it looked like WW3 BROKE OUT HERE FOR A WHILE. Anyway just as an interesting aside, my brother was helping me once with my 944 when I snapped a timing belt ( he is a mechanic ) and the first thing he did was put the head upside down on the bench and pour some gasoline in the cavity, he said if that gas is gone soon we will know you bent something. Sure enough all the gas leaked through in about 5 minutes....
Only one person acting juvenile on this thread..... same as usual. Got anything to add that may actually help out here Loren, or just your usual "look what an a$$ I am" comentary??
Cheers
Cheers
I'm not sure of the ramifications of trying to machine pockets in the old Mahle pistons, my guess is this isn't an option. That is one of the positives of JE pistons, in that they can design and then machine the pistons for the valves, which is often done with aggressive cams.
One of my build items are a set of racing valve springs, so they will help some with valve float, in the case of a future mishap. I'm also going to put a shifter, such as the Rennshifter on for further protection. That's a nice product, on the par of Wevo, IMO, and built by a nice guy in Ft. Worth.
I'd heard that before, way back when. Thanks for the tip, I'll try that and see what it shows.
Sounds good, Ed. I haven't done it but might research it next time as well.
I also did the race springs but not much can save a mis-shift.
I chose the Harget G50 unit and LOVE it! Moves the shifter much closer, positive feel, much shorter cleaner throws. I'll get pics if you want but you seem like you know of good options.
Best of luck!
Best of luck!
Ed, sorry I missed the engine drop, it seems like all I do lately is travel or work...no weekends.
I really wanted to watch... I mean HELP :-)). I have one of these in my future and you can only read Wayne's book so many times...seeing it in real life would help me a lot.
I'll probably photograph every nut I remove.
Note to earlier poster...SMU grad here. Fun place to go to school.
Buck
Buck
