C2 air conditioner
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
When you say system diagram if you mean a system layout diagram. Hard to find specific for a 964. Why, because it is the same as an other vapour cycle system. Wiring diagrams can be found at <a href="http://www.alldata.com" target="_blank">www.alldata.com</a> or in the factory maintenance manual or on Adrians computer.
Components locations chart same thing.
964 system consists of
Receiver dryer
Compressor and clutch assy
Clutch relay
Expansion valve
Evaporator
Condenser
Condenser 2 speed fan
Condenser fan relay
Air-conditioning distribution system (fans, valves etc)
Control unit
Ciao,
Adrian
911C4
Receiver dryer
Clutch relay
Expansion valve
Evaporator
Condenser
Condenser fan relay
Control unit
Ciao,
Adrian
911C4
