Carrera 3.2 Top End Rebuild vs. Rebuilt Engine?
Recently I had a PPI done on a Carrera 3.2 I wanted to buy. Glad I did because the leakdown test and fouling plugs showed the car needed a top end rebuild, estimated at $ 3K to $ 5K. I decided to pass on the car - tough when you like it otherwise, and the price is low. Later the experience made me wonder if replacing that engine with a rebuilt engine would be better than a top end rebuild because of the relative cost. I notice that Motor Meister sells a rebuilt 3.2 engine for $ 3,995 with an exchange, and estimating 10 hours to install (maybe $ 1,000 at a good shop) isn't that a better deal than a simple top end job since you'd then have a completely rebuilt engine for about the same price? Would that be a good idea, or am I completely missing something?
Originally Posted by jfk308
....or am I completely missing something?
Keith
'88 CE coupe
Factor in 10k for a good top end rebuild and make an offer.
Does anybody here have a receipt from a recent rebuild.....a stock motor not anything above stock? id like to see what shops are charging. it seems to make a big difference if the owner removes it himself etc. aka owner participation
I'm not sure, but Eric might have been thinking rod bearings up, including rod bolts, nuts & bearings, 24x new head studs, rings, and a complete valve job. At today's labor rates I can believe that he's right, because that was a $7-8K job when I still had my shop (in '99). Aggressively protecting yourself is never a bad idea, especially now that top ends (valve job only) are costing $4K, the above job costs $9-10K, and a "rebuild" costs $14K (including new piston/cyls). I witnessed many post pre-purchase negotiations, and I rarely saw a seller offer a price reduction of anything more than 50% of the work needed, and sometimes much less than that for a car that was already priced below market.
Pete
Pete
Peter is certainly them pays to become and learn to be a very handy DIY'r. I myself could not imagine NOT being neck deep in a rebuild of my 911..But then agains tyhere are some self admitted all thumb types.
You can reduce that cost significantly by pulling your own heads and sending them off to John Walker or EBS. $10k for a top end better include a happy ending
As a comparative price point, I just picked up my car with a rebuilt engine on Saturday Total was 10K for bottom and top end without new P & C's. This also included ARP rod bolts, EBS performance valve springs and titanium valve retainers, new oil by-pass thermostat and oil line, one axle, new cam towers, and powdercoating all the metal and valve covers. This started as a top end rebuild after kissing a couple of valves by missing a shift on the track, then I decided I wanted new rod bolts and it all went to heck from there (cracked rings, worn bearings, and ovalized pin hole on the crank nose).
This mechanic has a small race shop, a great reputation among the local racers and charges labor at $70/hour. I contributed none of the labor. The car runs great, and I am very happy with the work, so perhaps it will give you some perspective as you consider your purchase.
rickdm
rickdm
Thanks for the feedback on Motor Meister - it really is shameful that PCA allows them to advertise in Panorama given the history. If we remove Motor Meister from the equation, I still see other shops that offer rebuilt engines for a similar price. For example Air Cooled Classics (also in Panorama) sells a rebuilt 3.2 for $ 4K, and I've seen others that are similar. Assuming some of these outfits are reputable, my question still stands - if a top end rebuild costs $ 3K to $ 4K (and some posters have even paid $ 10K) wouldn't a rebuilt engine at $ 4K to $ 5K be a better alternative? Why just rebuild the top end when you can have an entirely rebuilt engine? Does it cost that much to remove the old engine and put a rebuilt one in? Again, am I missing something here?
