heater blower hose
03-24-2007, 11:29 AM
heater blower hose
Does anyone have a tip on how to keep the plastic blower hose on? I tried large metal hose clamps with little success. I pulled it off until I can figure something better. Thanks for the advice.
-Nathan
03-24-2007, 11:30 AM
Sorry, by the way it is a '77 911 coupe.
03-24-2007, 11:49 AM
03-24-2007, 02:43 PM
Team Owner
Do you have a pic of what you are talking about ? may help.
03-26-2007, 09:10 PM
pictures
here's a couple of pictures:
03-26-2007, 09:11 PM
Team Owner
Mine stays on without clamps and just presses in . Did you try large black tie wraps ?
03-26-2007, 10:47 PM
heater hose
I've used large metal band hose clamps. It holds on the motor side, but not the side near the fan shroud.
03-29-2007, 12:11 AM
I'm going from memory because mine is up on a lift now, but I recall that there are one or two screws through the holes on the end in addition to the clamp; one of the holes I'm speaking of is visible in your photo. They don't require much strength to hold, just screwed into the plastic.
03-29-2007, 09:17 AM
Now that would make some sense, you wouldn't know off hand what the screw is, would you?
03-30-2007, 12:18 AM
Quote:
No I don't, it's just a black self tapping sheet metal type screw that can hold the two plastic pieces together.
03-30-2007, 09:09 AM
Nathan,
There are no screws in that assembly.
The factory band clamps have pins that locate through those holes and prevent the hose from blowing off. The correct part is around $3.
Paul
03-30-2007, 09:25 AM
Thanks for the help guys.
