Fuel Filter
Fuel Filter
I'm replacing my fuel filter today. First of all...what a dumb *** location for that thing. Even with all the hoses removed, it's very annoying to get to.
When I was removing my old filter, I spilled a lot of fuel into the engine compartment. I sopped most of it up with rags and I'm letting it dry out before I start the car to test for leaks.
But I'm still nervous something may start a fire. Do you think I'll be ok?
I'm sure we all spill some the first time. Use a big rag under the filter next time.
Ian
dont prime the system when you go to start it just crank it till it starts. I just changed mine and primed it and flooded it up. I had to pull all the plugs and blow all the gas out it was not fun.
Every 60,000 miles.
If it's clogged it could cause a problem.
Originally Posted by GothingNC
I've read somewhere that it should be changed more often or once a year if you are using fuel containing Ethanol.
Legacy Flounder
Ethanol reportedly "cleans" any crud in the tank that's been built up over the years. Once you've gone through a couple of filters, it SHOULDN'T be an issue any longer. It's not that bad of a job once you've done it, so I've been replacing mine each spring / valve adjustment anyway. I keep one on the shelf & order a spare when I go to use it (I have one on the way in from Pelican now, along with the silicone cover gasket & new hardware, plugs, & oil temp sender).
