Windows fogging up really bad in the rain
And its not from my heavy breathing when I am driving too fast for conditions. As you can see from my avatar, I have a Targa. If I drive in the rain, the car fogs up really, really bad.
I know I need to make sure that it is completely sealed up and not getting wet inside, but what can I do in the meantime (as in between now and me finding the leaks and sealing them) if anything? I tried the RainX FogX solution, which I hated. A guy I know was saying that he has something that kind of draws in the condensation in your car. He said that it fills up after awhile and he just empties it. He was saying that alleviated his fog issue in an older pickup truck he had. Let me know what you guys think!
Jeremy, I think you or friend are referring to "DampRid".....I have used it in the garage to obsorb moisture....it works. You pour the cystals in a plasitc contaniner and it will fill with water. The website is www.damprid.com
On my Targa, I run the A/C and sometimes I open the fresh air, but usually the A/C is sufficient.
Sometime you have to turn the heat on full blast, along with the fresh air on full blast, along with the defroster. But Jack might be right, because you shouldn't be having that much moisture coming in. I would also check that your fresh air screen is not broken, since the screen is what lets only air through.
A/C will only help if the Rh of the incoming fresh air is high enough, otherwise it will actually be a hindrance, bringing the system airflow closer to its dewpoint, more "willing" for the moisture to condense on a cold windshield.
The best solution I have found is to lower the windows just slightly, put ALL of the HOT airflow toward the defrost/defog/demist ducts and use the HIGHEST blower speed.
Once the condensation evaporates from the windshield leave it there until the interior windshield surface is heated well above dewpoint and then gradually reduce the blower speed to a less discomforting level.
This can be extremely discomforting but not as much so as 6' feet under.
If you have A/C its best use is with the blower speed at minimum.
In the race car we always kept a squeegee on a piece of broom handle where the drivers could easily get it and wipe the windshield clean. When you're all strapped in you can't lean up enough (at all) in order to swipe with the back of your glove or a rag. We had a fresh air blower to defog the windshield, but in a Sebring rain in the early evening when it was getting cool it couldn't keep up.
We also wiped the inside of the windows with Dawn dishwashing detergent. It seemed to really help in that situation, but it had to be Dawn, some of the other brands wouldn't work that well. Rain-X and Fog-x didn't seem to work well at all.
I wouldn't think Damprid could pull enough moisture out of the air of a moving vehicle fast enough to make a difference about condensation on the windows, but I've never tried it either.
I find that sometimes going thru puddles allows water to hit the exhaust, steam and enter the air ducts thru the two dampers that allow the air mixing at the rear. It's another one of those "what were they thinking?" deals.
SRF506, you are right, DampRid is not intended to handle immediate window fogging. It will reduce moisture in the vechicle over a period of time....it is better suited for cars being stored or not driven regularly....
