Got a misfire and an MSD?
To make a long story short: I installed an MSD igntion in my 1980 911SC. Everything worked fine at first but then after a while the car developed an occasional misfire at mid rpm. I replaced the plugs and the problem went away for a while, but returned. I replaced the coil and the problem went away for a while, then returned. Over the last 5 years I have replaced the plugs numerous times, replaced 2 coils, rebuilt the Webers a dozen times, replaced the plug wires twice and the cap and rotor twice. I've had it on a dyno twice with wide band o2 sensors and was told(by an expert from California who shall remain nameless) that the exhaust pipes were too big for Webers. Smaller and smaller pipes were put on and a new distributor installed-every one of these things seemed to clear up the problem, for a while. Now, the car made 285 hp at the crank, even with the misfire, but the o2 sensors showed it running at a very rich 10:1 ratio in the mid range. I finally broke down and replaced the MSD box with a new digital model, and the misfire remained-haunting me with it's occasional pop. After all that, what was the actual cause of all the problems? The two wires going from the distributor to the MSD box were reversed. This caused a weak spark so with new plugs, perfectly tuned carbs and the right weather conditions, the car ran fine. But as soon as conditions weren't perfect, the weak spark would stop firing a plug or two. The car now runs absolutely perfect, you would think it was a modern fuel injected engine except the throttle response is far better-I wonder what it will make on the dyno now?
Randy:
It sounds like the trigger wires were connected out of phase from each other and that results in a 12 degree ignition retard. One should always check this with a timing light at every MSD installation.
Not good for proper running & performance as that results in a weak spark and sub-optimal timing,...
"12 degree?? That part, I don't get. But thanks."
The variable reluctance (magnetic pickup) type of distributor produces an asymmetrical signal
for triggering, i.e. a very fast negative falling edge and a slow rising positive edge. If the signal leads
are reversed, the slow rising (now slow falling edge) causes the timing to be retarded more so
at the lower RPMs and at idle where the timing is set. As the RPMs increase, the timing doesn't
follow the normal advance curve because of this.
Webers
Not to highjack your thread but can you tell me more about your experiences with switching to Webers from CIS?
I really don't like the CIS system with it's surging and stalling and my car is old enough to not need to comply with emissions so the Webers seem like a viable alternative.
Originally Posted by randywebb
ok, the trigger wires - are you saying you had the msd green & purple wires swapped initially where they connect to the coaxial green Porsche cable?
Originally Posted by rbuswell
Loose:
wait, I did the same thing and you didn't notice the ****ty running conditions? The thing should of ran like crap. Really weak, and it shakes and rattles oddly. your's didn't? That is really weird.
