Pop off....cork?
My 79 SC has what looks like a factory pop off plug, held in loosely by the normal vacuum. Right side of airbox, about a 1" opening, barbed rubber plug. Can push it out easily, but seems airtight when running... anyone else have this? Definitely not aftermarket...
Am I off the hook for a "proper" pop off valve?
Off to John Walker's shop Tues for the tensioner upgrade and a valve adjust..
It's just a plug that was for a breather hose that's not necessary in your application. The plug prevents unfiltered air from entering the engine. It's not a pop-off valve, which is another story...
Pete
Pete
Pete
Pete
In addition, I think this is the hose that holds the backfire grid (flame arrestor). See a post I made earlier when mine was missing.
http://forums.pelicanparts.com/showt...=backfire+grid
autobonrun,
That's the part I'm referring to. I know it's not a proper pop off valve, but the slightest positive pressure should send it right out.
I'm gonna use it as a pop off for now...
Car runs great, so I assume nothing is missing/disconnected. Unless it's smog crap, in which case, I have a special box for that.
Originally Posted by Eric_P
autobonrun,
Eric,
The plug you are looking at is neither a pop off cork or a flame arrestor, it is a remnant of CIS evolution. Porsche moved the oil tank breather after they realized it was plumbed into the wrong side of the air flow sensor. I am not sure of the production date change, but it may mean you have a replacement air box, if you are interested. It cannot function as a pop off anything because it is on the other side of the air flow sensor.
Paul
Paul
