Getting a Bursch Muffler
The open exhaust sound is unbearable for such a classy car. Can even beat my self up to pay over 500 for a freaking muffler
Fausto, if you want a really great sounding muffler look at the M&K Mufflers. I have heard a few different ones and they sound great. They're also much lighter than OEM style mufflers and use better grades of stainless steel. Euro East is the best place to buy for the price. Their website is euroeastparts.com. Tell Jerry I sent you and he'll take good care of you. As soon as I have the money saved up to replace my OEM muffler I'm doing a M&K 1-in 2-out.
I did quite a bit of research and I installed a M&K (single inlet with dual outlets). As stated earlier, it reduced weight by 13lbs and it looks great. It sounds wonderful when accelerating and cruising (fairly quiet at cruising). At idle it is a tad loud, but not too loud....and M&K does make a cap for one of the outlets if you really want it to be quiet. I put resonator tips on it and this made it smoother. It is louder than stock, but it sounds great...If your Bursch is a dual outlet, you could consider restricting the flow from one of the outlets. There is an electical cut-off valve that can be installed and there is also a valve that operates through exhaust pressure (it is closed until you punch the gas). If interested, I think I can find the sites for these cut-offs.
The Bursch is adeqate, but will give you a tinny & rattling sound. I believe they are made in Mexico. Mine made a rattling sound when accelerating/decelerating. The thin sides of the muffles flex when the get hot and when on decel, they were hitting the inner support. Sound was OK, but rattle drove me nuts.
in would seriously think about m&k and fabspeed. i have a fabspeed on my 996 and it is REALLY nice. the problem is the price...a lot of the p car club guys run the m&k and they sound sweet , but a little resonance in the early rpm range...
The Bursch are ok sounding, the finish is terrible, the paint will either flake off or burn off, so you may want to get it blasted and ceramic coated, or paint it yourself.
I read a lot of posts about people raving about how good the M&K mufflers sound, and how inexpensive they are, but I've yet to see published data showing what effect they have on power output. In fact I have heard reports that HP actually went down when tested against other alternatives. Based on this, I'd be wary. I think there still is no such thing as a free lunch.
You can always get a Magnaflow in there. That's what I run on my headers, it fits behind the valance where it should, and uses the stock strap hanger.
Ed, I agree with you that there is no significant data showing M&K increases performance....but, "looks" and "sound" are important. Does the magnaflow improve performance? The only ones I have seen that have a positive increase on performance includes other modifications i.e. SSI, by-pass pipe, etc...
