Groan on turn-Calipers?
I just completed 250 miles of spirited driving this weekend and the groan had not come back.
Now that I mentioned it, the sound is sure to come back tomorrow
John
John
My 88 made the same noise you described when I bought it. Try this, when the moan occurs just slightly touch the brakes. I bet the moan will stop. That is what I did. I rebuilt my front calipers and replaced the pads and the problem went away. When I took the right caliper apart, i discovered that someone before me had the pistons in up side down...
Dan.
Dan.
Dan.
Dan.
Murphy: Many times hose replacement alone fixes the problem.
MTB: Yes, when I say "reseal" I mean rebuild. I think that reseal is a more accurate term, because all that is normally done, other than careful cleaning, is to replace the piston o-rings and dust boots.
Pete
Pete
Originally Posted by murphyslaw1978
Yikes! I'm actually afraid to get into the brakes on my car. I am thinking about a DE event, so I will probably change the fluid and rubber flexible brake lines on all 4 sides, but I'm wondering what else I'll need to do.
If your going to do DE's I would suggest using braided brake lines.
Im going to order the SS braided lines and replace them in the next week. I noticed there are DOT "approved" and non-DOT approved ones for sale, and the non-DOT ones are less expensive.
Which ones work better? I was looking at the Pelican site for these items.
Thanks!
Thanks!
I'm not a fan of braided lines, until it's time to go racing. Then buy the Kevlar braided, DOT approved lines. Never buy lines that are not DOT approved. For an occasional DE, and most driving done on the street, I would use only factory o.e. rubber lines.
Pete
Pete
I had a problem after replacing the AC system on my 85 euro 930. We didn't get the AC hoses in the left front wheel well back in their proper position. When turning to the left it'd set up a tremendous howl/groan from the tire when they hit the hose. Loosen the mounts and getting them in a better position made it quiet again.
Jim Parker
'85 euro 930
'84 euro Carrera 3.2
Jim Parker
'85 euro 930
Mine does it, too, though only under hard use at the track on infield sections. It sounds a lot like a goose! Good call!
I also checked wheel bearings and everything else...no issues. I think it is the caliper that gets stuck with high heat. I don't think it's tire rub (at least on my car) because the noise continues a bit even when a straighten the wheel. It also takes a few laps to go into full song.
Well the fog horn noise started to come back- sounded like a freight train horn
It only happens on the street corner when I'm driving into my sub-division and this time the noise continued after I straighted the wheel out for a second until I tapped the brake pedal.
I jacked up the wheels last night and I felt not play in the wheel bearings but when I turn the wheels I can hear the brake pads scraping more on the drivers side which is where the source of the noise is coming from.
All 4 calipers were rebuilt and new hoses were installed 4 years ago but maybe one of them got gummed up from sitting for a few months the other year.
Pap Parts has the kit $20 for both wheels.
John
John
I got my 88 targa in May and have experienced the same issue, not often, and usually after braking and turning slowly, like into the driveway or into the garage, but not too often on regular runs.
The car had been a garage queen and I thought the caliper was sticking some (due to lack of use) to cause the noise.
I will probably have the calipers resealed and new pads installed when it is time for a annual service. hope that will take care of it. It isn't going to be a "GQ" any longer.
