911 Forum 1964-1989
Hibernating Targa
Old Jan 31, 2007 | 01:08 AM
jwt996's Avatar
jwt996
Smile Hibernating Targa
My 88 Targa has been sleeping in my garage since October. I knew the battery would be dead, but I did not think about one of the tires going flat...The tread is good and I think it is just a slow leak due to inactivity. Do I need to be concerned, or just re-inflate the tire when Spring arrives?
Old Jan 31, 2007 | 07:25 AM
BMWDavid's Avatar
BMWDavid
I would reinflate the tire as soon as possible. There is a possibility of damage to the sidewall from the rim/wheel flange pressing into the tire.
Also...remove battery or try to put a Battery Tender type of charger on it. I don't know if your garage has any heat, but if it can get below freezing a dead battery can freeze and crack. That would not be pretty having battery acid splilling into the car.
David
Old Jan 31, 2007 | 10:31 AM
Jay H's Avatar
Jay H
I agree with David that you need to address the flat tire issue before you damage that tire. Since you can't drive the car, now would be a good time to get that rim and tire off the car and get the tire repaired. Inactivity will not cause a tire to go completely flat. You may loose a few psi over the winter storage months, but never enough to completely deflate a tire that was left at the proper pressure when put away.
Also, for winter storage, pump up the tires to the maximum pressure that is noted on the sidewall. That helps a bit with flat spotting of the tires for cars that are stored for the winter. Just remember to set the pressures correctly when you yank the car out in spring.
Jay
90 964
84 3.2
Old Jan 31, 2007 | 11:41 AM
theiceman's Avatar
theiceman
Team Owner
also parking on a piece of dense styrofoam helps preserve the tyre. Personally I use carpet and have never had an issue.
Old Jan 31, 2007 | 11:49 AM
Mike Murphy's Avatar
Mike Murphy
IceMan, I, too, would love to park my car in my living room, but the girlfriend won't let me!
Old Jan 31, 2007 | 12:30 PM
theiceman's Avatar
theiceman
Team Owner
whats wrong with you man .... get that girlfriend traded in .... newer models are always available ..
Old Jan 31, 2007 | 01:57 PM
jeffnudd's Avatar
jeffnudd
Same here but i think the oil leaks would show up on a cream carpet?
Old Feb 1, 2007 | 01:40 AM
jwt996's Avatar
jwt996
Thanks for the replies. Spring is just around the corner and looking forward to waking him up!
