New baby is home- '83 911 SC
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Details:
1983 911 SC 150,898 miles
- Manual transmission. It was rebuilt 100 miles ago. Gears 1, 2 & 3 were replaced with all synchros and sliders.
- Turbo tie rods (aligned and corner balanced 3/13/06)
- B & B Stainless exhaust headers with heat
- 7 x 8 x 16 Fuch wheels
- Custom door panels/arm rest
- Factory short shift kit
- Boxter seats ( partially powered)
- New carpet kit and trim
- New door seals
- Carrera chain tensioners
- New Sachs power clutch assembly 3/14/05 at 132K
- New Rotors and master cylinder 2/12/02 at 112K
- New brake pads all 4 corners 10/03/06 at 148K
- Replaced all vacuum hoses throughout ownership
- Replaced large intake boot 11/06
- Replace Ignition coil, injectors, oxygen sensor 10/19/05
- Tires are 20% worn
- Replaced return tube oil lines 10/19/05
- Bilstein sport shocks, all 4 corners 3/5/03 at 116K
- Miscellaneous - spark plugs, seals, fuel lines throughout ownership of vehicle
- Fuel pump and fuel accumulator and spark plug wires
- Paint bubbling repair left upper cowl (about size of quarter) 7/26/04 from work windshield seal that leaked (windshield seal obviously replaced as well)
- Front bumper cover repair 11/12/04 due to minor fender bender (while vehicle was in shop, also had front and rear valances refinished) - Copy of the final repair estimate/invoice provided
- Valves adjusted and oil changed before purchase.
- Leak down numbers from 10-19-06 (around 20k miles ago...) - Cyl #1 8%, #2 7%, #3 9%, #4 9%,#5 8% #6 6%
- The Rev Limiter Relay, A/C and the cruise control are the only components on the vehicle that do not function. The A/C has all parts installed but the system will not hold a vacuum. The end of the cable connector for the cruise control is broken - the entire assembly needs replacement. The Rev Limiter Relay is not working correctly and needs to be replaced.
And here are the photos:
Rear wheels are one year old... front were refinished at the same time... very nice looking:
- New door seals
![](http://forums.rennlist.com/upload/911sc1.jpg)
![](http://forums.rennlist.com/upload/911sc4.jpg)
![](http://forums.rennlist.com/upload/911sc5.jpg)
![](http://forums.rennlist.com/upload/911sc6.jpg)
![](http://forums.rennlist.com/upload/911sc7.jpg)
Now for the bad part... paint retouches were not done, how should I put this, correctly... not concourse by any means.
Here are the photos:
They should have eliminated the sticker.... instead it was painted around it... This was one of the previous owners that the person I just got the car from...
Here you can see some of the clear coat coming off...
more clear coat coming off... here from around the hood crest...
![](http://forums.rennlist.com/upload/911sctbad1.jpg)
![](http://forums.rennlist.com/upload/911sctbad4.jpg)
![](http://forums.rennlist.com/upload/911sctbad2.jpg)
![](http://forums.rennlist.com/upload/911sctbad3.jpg)
Jamie
Very nice, looks like a very nice beasty. How do you like the seats? Do they fit well/do you like the way they sit in the car? Like the panel treatment on the doors...nice momo...
Congrats!
Frank
Congrats!
Frank
Originally Posted by panchosouth
Jamie
Congrats!
Frank
Congrats!
Frank
![](http://forums.rennlist.com/upload/seat_for_sc.jpg)
I also have RS Americas door panels and H4 headlight arriving Wednesday...
Looking to make it into an RSR 3.0 replica... it will take years... but little by little...
Originally Posted by VA911
she is looking good apart from some minor paint issues. Love the colour!!!
enjoy!!!!
enjoy!!!!
My first thought was... man, this is too nice looking for what I want to do with it... those flaws in the paint will actually help me do the changes I want without feeling too bad...
Originally Posted by Wachuko
Seat are from a Boxster... comfortable but you tend to sit higher than normal. My plans are to swap those for some Recaros SRDs (I have had one, drivers side, in the garage for several years waiting for a car like this...will need to buy the passenger side).
F
That car was for sale on Pelican for a while, right? I remember the door panels in particular. It's a very pretty car...great color.
Before you ditch those door panels, could you post what company made them (if you are able to tell from the panel or if you have the paperwork)? I'd love to buy a set of those in black, and cannot fin any other pictures of those except that want ad with this (your) car!
Im pretty sure there is an outfit advtsing in the back of Excellence...dont have one on hand to check....
