Safest place to support a 911
Here goes another post.
As part of my winter to-do list, I am replacing the worn spring rear plate bushings. Normally when I support the car I support it on the spring plate arm(?) that sticks out at the torsion bar area. But, when I am pulling the spring plate off, that "arm" comes with it. So where is a safe place to suport the car while I work under it? My wife says don't worry cause she bought a new life insurance policy on me.
Thanks,
Scott Harris
1973 911T Targa 2.4L MFI
Thanks,
Scott Harris
I usually lift the car via floor-jack under the tranny. Place a rubber pad between the jackpad and the tranny case as not to damage the 915 housing. Then use the jackstands under the tranny.
Or, see if you can rent a few hours of lift-time at the local shop, $30 and a few beers should suffice.
