911 Forum 1964-1989
My first 911 project list
Old Nov 20, 2006 | 06:40 PM
gunlover05's Avatar
gunlover05
Default My first 911 project list
Bought my first 911 a few months ago - basically stock 85 coupe w/ 86K miles...been reading a LOT on this forum, pelican's, and 101 Projects (which i absolutely love). Just spent time looking all over it and cleaning mostly although I already fixed a little surface rust @ the battery compartment...Car runs pretty strong and in good shape, but the PO didn't keep maintenance records ;-( Car is lowered to Euro spec. I'll mostly be street driving, but will try an autocross in the spring for sure...Here is my project list in order I think I'll do them that I've compiled so far.
Brakes - Pads OK, will replace lines and flush fluid
Engine - will adjust valves + replace oil. Gas lines look replaced (have a wrapping around them, not just rubber). Run some Techtron asap
Ignition - will replace spark plugs, cap/rotor, air filter, and plug wires while I do the valves
Tranny - replace fluid w/Swepco and adjust
Body - door seals on body need replacing
Suspension - replace sway bar bushings (a few are torn), turbo tie rods when ultimately needed. I have bilstiens front and boge rears which seem fine now.
Engine - replace cylinder head temp guage w/2 wire
Bunch of little things like aim the H5 headlights (eventually go H5s)
What am I missing? Did I miss anything on the order?
Old Nov 20, 2006 | 06:54 PM
IslandmanPA's Avatar
IslandmanPA
First thing you can do is POST SOME PICTURES!
File Type: gif
Old Nov 20, 2006 | 08:35 PM
gunlover05's Avatar
gunlover05
Default thought you'd never ask....
back in black...
Old Nov 20, 2006 | 08:39 PM
gunlover05's Avatar
gunlover05
Default and a few more
Old Nov 20, 2006 | 08:43 PM
gunlover05's Avatar
gunlover05
Default yep, and a few more
Old Nov 20, 2006 | 08:47 PM
gunlover05's Avatar
gunlover05
Default does this pic make my butt look big?
Old Nov 20, 2006 | 09:07 PM
lally911's Avatar
lally911
- consider putting in speed bleeders while bleeding the brakes. Makes bleeding them the next time much easier
- make sure you get the filler plug loose before draining the old gear oil.
- Lots can be done to refresh the suspension. Original rubber torsion bar bushings are most likely hard and have flowed out of shape since 85. Elephant racing polybronze bushings are a nice upgrade. Check the front cross brace between the two forward a-arm pick up points for rust. Three rubber plugs can be removed and some poking around for soft spots should give you an idea. Corner balance, alignment, and new stick tires would be good too.
85 was a good year :-)
Old Nov 20, 2006 | 10:18 PM
IslandmanPA
You're on the right track! I also suggest an exhaust upgrade! Love the sound of a throaty muffler on a 911. There's a clip of my B&B on my rennwebsite. Under Islandmanpa.
Old Nov 20, 2006 | 10:23 PM
IslandmanPA
Keith,
Nice website!
Old Nov 20, 2006 | 10:47 PM
JV911's Avatar
JV911
I'd hate to be a pain but can you provide link. thanks
lally911's Avatar
lally911
Thanks!
Old Nov 20, 2006 | 10:50 PM
IslandmanPA
If you click on a members name, there is a drop down with ways to view profile, send message, send PM, etc.... also includes access to listed websites. Here's mine:
http://members.rennlist.com/islandmanpa/
Old Nov 20, 2006 | 11:17 PM
SeattlePorsche's Avatar
SeattlePorsche
Maybe a new fuel filter?
New tie ends until you replace with turbo tie rods. If you count the threads on the tie rod exposed, you can put the new tie rod in with the same alignment.
Nice low mileage car!
Old Nov 20, 2006 | 11:59 PM
JV911's Avatar
JV911
wow! great site and the exhaust sounds MEAN
i should create a site too...unfortunately i have no idea. posting on these forums is about as technical as i get
Old Nov 21, 2006 | 12:46 AM
Droops83's Avatar
Droops83
Congrats on the purchase, welcome. Nice sports seats! Looks like you have compiled a good list, I have a couple things to add if I may:
Great suggestion, change it soon, who knows the last time it was done.
Yeah, you can get it close but I'd still check the alignment, especially since it's an unknown car with "Euro ride height. . . "
I personally would not want mismatched shocks, look into getting Bilsteins for the rear as well when you tackle the rear suspension, they luckily are a bit easier to change than the fronts.
Check the clutch adjustment.
Check compression while you have the plugs out if you can.
Make sure you have a spare fanbelt (and the tools to do the emergency change if necessary!) and that your existing one is in good shape and at the correct tension.
Make sure you buy a spare DME relay and keep it in your glovebox.
Monitor your oil consumption!
Have fun and enjoy your car! Don't hesitate to ask questions here.
I may have forgotten something, I'll post if I think of anyting else.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
