911 Forum 1964-1989
My first 911 project list
Old 11-21-2006, 01:37 AM
r911
Anti-Cupholder League
r911's Avatar
yes - you will want to replace every rubber bushing in the suspension
- that will keep you busy for a while
Old 11-21-2006, 09:31 AM
GeneralTso
GeneralTso's Avatar
Nice 911! Congrats on the purchase!!!
Old 11-21-2006, 10:40 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,142 Likes on 816 Posts
If you are pulling the rubber brake lines it is s good time to remove the caliper and repack the wheel bearings if not replace them as the hub needs to be removed to do this.
Old 11-21-2006, 01:51 PM
gbailey911
gbailey911's Avatar
Default brakes
Usually the last thing any of us DIYers think about is the brake calipers themselves. My 1987 had one front caliper hang up a couple of weeks ago so I took it off to rebuild or replace. Prior to removing, my brakes were what I considered awlsome. Upon disassemly, I was shocked to find it junked up with crud and varnish and almost impossible to disassemble. I have since removed and rebuilt all four calipers and all four were in the same shape as the first. Caliper rebuild kits are about $11 each and worth every penny if it keeps you from having a caliper stick and shuting you down.
Old 11-21-2006, 03:14 PM
gunlover05
gunlover05's Avatar
all good advice guys! for sure have added some to my "list".....keep'm comin' if you've got'em...
Old 11-21-2006, 03:15 PM
IslandmanPA
IslandmanPA's Avatar
Put an extinguisher in it!!!!!!!!!
Old 11-21-2006, 04:14 PM
gunlover05
gunlover05's Avatar
Talking
yep, I did buy a regular FE and tucked in the front trunk...will look into mounting it in the cabin when I get some of the other projects on this growing list done
Old 11-21-2006, 05:02 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,724 Likes on 1,071 Posts
Originally Posted by gunlover05
...replace cylinder head temp guage w/2 wire...
Question - when was the temp gauge changed? I have an '88. Do I need the update?
Old 11-21-2006, 05:03 PM
Mike Murphy
Originally Posted by Droops83
...Make sure you buy a spare DME relay and keep it in your glovebox...
How important is it to have a spare relay? Just as important as the spare fan belt?
Old 11-21-2006, 05:12 PM
Mike Murphy
Congrats on the new purchase. My 911 was acquired about 4 months ago, and I have done a few things to it, including changing all fluids and filters. You just don't know what the PO did before you. I actually found a K&N air filter, but tossed it, along with the K&N fuel filter. I replaced both with stock. I'm trying to keep my car as stock as possible, including the oil. I run Shell Rotella T 15W-40, which is now considered heavy duty truck oil. As long as you are into the preventative maintenance (and you seem to be), you'll be in good shape in the end
Old 11-21-2006, 07:24 PM
madmmac
madmmac's Avatar
Congrats....make sure you are getting full throttle, floor it with the motor not running and take a look at the the throttle linkage in the motor compartment, it should be just about touching the stop...If not, adjust the linkage down by the transmission---usually about 3 to 4 turns moving towards the front of the car is all you should need.
Old 11-21-2006, 09:46 PM
theiceman
Team Owner
theiceman's Avatar
I carry a red and black realy, never used them but great piece of mind. Don't think I need botht but they were cheap.
Quick Reply: My first 911 project list
