Automatic Temp Control Repair - Control Cable Replacement
1 Post
Hi Everyone. I have an 85 930 that has an automatic temperature control unit. Recently, the control arm popped off the drive mechanism, so I relaced the ball joint caps. Upon further inspection, I found that the reason the drive arm failed was due to the sheath that runs from the unit to the flapper box had broken. The control wire became bound up and stalled the drive motor.
Has anyone replaced the sheath before? How difficult is it(is it a PIA)? Do you know what the part number is?
Thanks in advance,
Dave
Thanks in advance,
Dave
