Need eletrical diagrams/ help -930 engine in 911SC-
Hi
I have installed the engine in the car (1983 Turbo engine into a 1978 SC car)
Everything looks good but one thing.
The 14pin conector between the engine and the car,is the same but the wires inside the conector isn't matching. Seems like Porsche placed wires for the same function in different places on SC - turbo. The conector is the same.
Does annyone have eletrical diagrams showing the difference?
Does annyone have a car(911 SC) with a Turbo engine instaled?
If so would you be willing to take a look at your car and see witch pins in the conector, have been switched to make it work.
Gratefull for all help.
Thank you
Knut.
Thank you
Knut.
