View Poll Results: How many '87-'89's with broken Dilavar head studs?
Broken studs
4
21.05%
No broken studs
8
42.11%
Not sure
0
0%
Didn't realize it was an issue
7
36.84%
Voters: 19. You may not vote on this poll
Poll: How many '87-89's with broken Dilavar head studs?
I have a great running '87 3.2 at 141K miles but have recently become aware of the Dilavar head stud achilles heel. I have no reason to suspect a broken stud but was not aware of the chance to check when I did my last valve adjustment. How many of you have found broken studs? What did you do about it?
88 Carrera with 88,000 miles I found 2 broken studs when I did a valve adjust. I ended up needing the heads done and went to 3.4 P&C's. The car is stored winters and had the epoxy coated studs. IMHO dilavars will fail, it's just a matter of time. I wouldn't worry much about it until it happens. Mine fell out when I took the valve covers off.
when I had my top end rebuilt@100k miles they put my engine back together and test ran it when the shut down the motor one of the studs shot out and put a good sized hole in the cement floor.needless to say we replaced ALL the the studs.
A head stud shot out and put a good size hole in the cement floor? I must have had too many beers? the head studs run horizontally so how did one hit the floor. I will have to read this in the morning to see if it makes sense sober. beware of flying head studs! LOL
