911 Forum 1964-1989
Help, please, adjusting H-1's
Old Sep 22, 2006 | 11:31 PM
john d 81SC's Avatar
john d 81SC
Default Help, please, adjusting H-1's
The H-1 headlamps have 4 adjusting screws - 2 towards the top of the headlight rim, one on the inside and one on the outside, and 2 towards the bottom of the rim, again "inside & outside". Please advise which screws are for the vertical adjustment and which are for the horizontal adjustment. Also, is one set for the low beam bulb and one set for the high beam bulb? Thanks in advance.
Old Sep 23, 2006 | 12:28 AM
Droops83's Avatar
Droops83
There are only 2 screws on the H1s that actually adjust the headlight aim, they are the 2 that are behind the little rubber plugs on the ring. The one on top adjusts vertical aim on the one on side adjusts horizontal. The high beam and low beam adjust together, but id aim em using the low beam since that is most like what you'll be using more.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Old Sep 23, 2006 | 11:44 AM
john d 81SC
Chris,
Thanks for your reply, but I don't have any plugs - I have a "rim" that fits over the headlight, covering these 4 screws. It is held in place with a screw at the very bottom of this ring. With the setuip you describe, where are these plugs located?
Old Sep 23, 2006 | 12:28 PM
Peter Zimmermann's Avatar
Peter Zimmermann
John: The H1s that you have are a huge pain, and yes, they have separate adjusters for up/down and left/right for each bulb. The best thing that you can do is point the car at a garage door or similar and play with the screws - I can't remember which is which. I can tell you, that back when you still saw the H1s once in a while, that often the adjuster mechanism for one or more aim settings failed. It was bad enough that I think we were only able to adjust one out of three cars that we tried to set up - we sold a lot of H4s back then! Good luck with it...
Pete
Old Sep 23, 2006 | 12:33 PM
john d 81SC
Pete,
Thank you for your prompt reply! I'll play around with it.
John
Old Sep 23, 2006 | 08:16 PM
r911's Avatar
r911
Anti-Cupholder League
There is a diagram in the Haynes manual - do you have one?
IIRC, the low beam adjustment changes both bulbs - so you do it first. I might have that backwards, but I don't think they are ind. adjustments.
There are 4 adjusting screws, not 2.
Old Sep 23, 2006 | 10:14 PM
Droops83's Avatar
Droops83
Sorry for the bum advice John D, as Pete pointed out I got H1s confused w/ H4s. Guess I'm too young to remember H1s . . .
---Chris A.
Old Sep 24, 2006 | 02:47 PM
john d 81SC
Randy,
Thank you for the Haynes suggestion. Borrowed a copy. Am i interpreting this correctly that the "main beam" is the high beam and the "dipped beam" is the low beam?
Chris - no problem - thanks for your interest.
Old Sep 24, 2006 | 09:47 PM
r911's Avatar
r911
I think that's right - make 2 copies - one for the car & one for a filing cabinet...
be careful not to move the screws too much - if it comes out you'll probably have to remove the headlight from the bucket
Old Sep 25, 2006 | 11:52 AM
Peter Zimmermann
John: In case you haven't figured it out yet, on the lens you will find a letter, either "A" or "F", near each of the four screws (1:00, 4:00, 8:00 and 11:00 o'clock). "A" designates a low beam adjusting screw, "F" designates a high beam adjusting screw. As you look at the headlight the 1:00 screw will be for low beam up/down, the 4:00 screw will be for high beam left/right, the 8:00 screw will be for low beam left/right and 11:00 will be for high beam up/down.
Pete
Old Sep 25, 2006 | 06:01 PM
john d 81SC
Randy & Pete,
Thank you both!!
