Picture of oil and tranny drain plugs?
Does anybody have any pictures of the underside of a 911? I need to change my oil and transmission fluid and want to make sure I am undoing the correct drain plugs. I think that I have it, just want to make sure. Thanks in advance. By the way I have an '88 911 cab.
There are two oil drain plugs, one under the oil tank at the rear left. The other is on the left side of the engine case, near the bottom. Careful, the oil comes out fast!
There are two transmission plugs which take a large hex to undo (its the same size as a VW transmission plug hex if you are looking at the auto parts store) The top one is on the left (drivers side) about halfway up the transmission. Undo the top one first (too make sure you can refill) then undo the bottom one. Make sure you have a pump of some kind to get the new oil in.
