Engine won't start
replace the check valve and your hot start problem will be gone. You also need to either adjust the warm up regulater or replace it to fix the cold start issue.
Thank you Gumball, from what I've read and what has already been posted by others I believe this is where I should start, the check valve and the warm up regulator. That article from Pelican parts that was posted by Theiceman tells all about the warm up regulator. Will do that and if it won't solve the problem I'll take the car to a garage (but I thrust it will).
George
George
