Blocked Sunroof Drain Holes
The rear drain holes on my 74 coupe are clogged. Does anyone have any experience with this? I have tried blowing them out with air, but had no luck.
The Ancient One
Rennlist Lifetime Member
Insert a small diameter rigid wire from the sunroof area through the tube until you poke through into the engine bay.
I suppose you could use a wire coat hanger, but I would clip off the twisted part for fear of it getting hung up somehow inside the tube.
just did mine...i poured water in both holes to find the clog..its was the passenger side and i tried a coat hanger with no luck..i found a 3 foot metal rod..stuck it up through the eng. area and it worked...NO MORE LEAK..poured water in that hole and it ran right out...j
Try and locate some 12 or 14 gauge wiring. The kind you'd wire an outlet in your house with. Strip the casing back and one of the three wires inside can be used. You can cut any length you like.
