Do Zimmerman rotors need a break-in period?
Do rotors need the 200 - 300km break in period? Instructions with the front say so with no such warning for the rears and nothing about it in the manual. They are OEM.
The fronts arrived Saturday and I just noticed the small print warning that is only in their box.
I have three days of DE at VIR starting Friday. There will be no time for 300 km of breaking them in. If needed I will wait til I get back and run with the old.
Reg
Reg
I'm assuming that you're also installing new pads (along with the rotors)...I've always heard not to use old pads with new rotors, and it's the pads that need a break in, not rotors. The break in period varies, but you should be able to 'cure' them with minimal miles if you follow the pad instructions.
Keith
'88 CE coupe
Keith
'88 CE coupe
They got 200+ miles before track time. All went well at the track. The Performance Friction 97 pads and standard Zimmerman rotors complimented each other quite well. No problem whatsoever stopping.
Plan to put old pads back in for street use due to dust and noise of 97's. Any concerns other than seated old pads?
Reg
Reg
Most performance pads / rotors require a 'bed-in' process which consists of repeated (8 - 10) 60 mph to 30mph 'light/medium' braking with at least 1/2 mile between each brake application. Then drive around for several miles with little or no braking to let the brakes cool. This procedure gradually increases the component temperatures without thermal shock and mates the pad and disc friction surfaces.
Never set the e-brake when the pads are hot...
You will likely need harder stops than that to heat the pads up enough. Dave Z has a good bedding procedure on his website, http://www.zeckhausen.com/bedding_in_brakes.htm
You should not apply your ebrake while the rotors are hot. The ebrake has separate shoes that engage the inside of the rear rotor drums. The pads are not engaged as part of the ebrake.
Technical Guru
Originally Posted by afinepoint
They are OEM.
Originally Posted by JasonAndreas
SHW Automotive has been the exclusive supplier since 1996
Reg
