911 Forum 1964-1989
warped dashboard
Old Apr 15, 2003 | 06:30 PM
classic911's Avatar
classic911
Post warped dashboard
I have a warped dashboard (not cracked) around the defroster vent areas and some shrinkage around the center vent area. It is a chocolate colored leather dashboard. I don't think a dash pad would look good due to the warped condition, which isn't too bad but it is noticeable.
Any suggestions to improving the appearance?
Thanks!
Old Apr 15, 2003 | 07:38 PM
scottb's Avatar
scottb
Post
Go to the Pelican board and do a search. A couple of guys there have recently replaced their dashboards with good success. Not an impossible job, apparently.
Good luck!
Old Apr 15, 2003 | 07:55 PM
mducharme's Avatar
mducharme
Post
Hi, I'll tell you what I did. I removed a dash top on my 84 cab and replaced it with a new one from pelican parts(466.00). The old dash was sitting on my work bench taking up space so I decided to have a go at it. I rounded up six peices of 2 by 2 by 1 wood , cut them to fit for the warpage, wet the area (under side) and clamped it with welder quick clamps. I used a blow drier to speed up the process. Let it sit over night with the intention of repeating the process if need be. Only needed one treatment for the area around the defroster vents. The center vent took a little more finesse but basiclly the same idea. I would put my used dash back in before using a cheap coverlay. Don't forget you gotta stare at that thing every time you turn the key. I wasn't sure if it would work but it did. It would have saved me alot of money. I hope this helps
Mike (mducharme)
Old Apr 15, 2003 | 08:18 PM
Doug&Julie's Avatar
Doug&Julie
Post
I bought one of those coverlay plastic covers for my cracked '72 dash. I don't care for it. It just doesn't fit right without A LOT of filing/fitting/adjusting/more filing. I lost patience with it and just stuck it in. Eventually, I'm just going to replace the dash. (But doesn't that require front glass removal?!??!) Anyway, I would avoid the coverlay thing.
Good luck.
