Fan Belt and A/C Belt Autozone Part Numbers ??
Lifetime Member
Lifetime Member
Originally Posted by theiceman
I would have thought 11mm to be the width
anyway i guess it doesn't matter as the shims will vary is all I would imagine.
-Chris
Team Owner
Hi Chrys
Don put the belt on , I iwas just commenting on the size, but it does sound like he has had success. I use the contitech belt and it works fine. I personally think overtightening is a bigger problem than under, if you undertighten it may slip a little , overtighten and you can destroy your alternator, or at least your bearings.
