MSD install question
Intalling and MSD 6al onto a carb converted 3.0SC engine. Two quick questions. On the coil it's marked A and B which is + and - ? Is A + and B - ? As far as the distributer goes it has a shielded type wire is the core + and the shield - or the other way around? I wired enrything up so I could switch them if necessary but I'd like to know for sure before I try to start it.
[quote]Originally posted by A Quiet Boom:
<strong>Intalling and MSD 6al onto a carb converted 3.0SC engine. Two quick questions. On the coil it's marked A and B which is + and - ? Is A + and B - ? As far as the distributer goes it has a shielded type wire is the core + and the shield - or the other way around? I wired enrything up so I could switch them if necessary but I'd like to know for sure before I try to start it.</strong><hr></blockquote>
Hi:
I e-mailed you directly with detailed instructions on how to hoook up the MSD. Hopefully, that will help get you going.
Hi:
