Any comments on the durability of the C4's?
Gary:
I assume you are posting about the C4's from 1989 to 1994. I invite you to post on the 964 board. You may get a few more bites there...
The C4 system is relatively robust. I have not heard of many large drive train failures on C4's. Keep in mind that AWD systems spread the power and torque between 4 wheels and related components vs. two drive wheels on C2's. That means each wheel receives less stress than on C2's.
The C4 and C2 have almost identical 0-60 times. If I remember correctly, only top speed suffers on the C4 due to drive train losses.
The weight penalty is about 270 lbs.
Hope this helps,
Jay
90 964
Hope this helps,
Jay
90 964
