Confused about vent/ac settings.
My 78 SC's owner's manual shows a diagram of the vent/defroster controls with 4 ***** (2 on top, 1 middle and 1 bottom). I have the factory a/c, but have only 3 ***** on the vent panel.
So what setting works if I want outside ait through the center vents without a/c?
Thanks.
Ulrich
Thanks.
Ulrich
Note: Non AC cars are different & the system is so confusing I might be wrong . . .
Ian
On my non a/c '78 SC, I just open the vents on the dash and in comes the outside air.. mmmm refreshing. But then again, mine only has 3 controls.. fan speed, heat (that can go from feet to dashtop) and cool (that can go from feet to dashtop). Not sure if this will help you though...
I think that Porsche designed these cars' Ventilation systems so that only a graduate in quantum physics could even come close to understanding it....levers, pulleys, *****, all scattered everywhere....at least my cab has seat heaters so that I can drive it in the wintertime...those things REALLY get hot!
I've had my '84 since April or May and haven't figured it out yet... I've read the manual, done everything... I have no idea how to make the thing work. I love the car, but boy do they have controls scattered all over the place!
On the dash...... top two horz. sliders go like this..
one on left opens outside air dampers (period)
The one on right is for (yes) fan speed the fans in the footwells only!!!!
two sliders below are for direction of air... footwell or defrost
the two pulls between the seats are for the actual heat from engine one on passenger side does passenger side heat....
and drive side is drivers side.
As soon as you move these ***** the top fan in your engine compartment should come on and moving warm air to the cabin and then the dash controls take over........ move the between the seat **** up and down to control temp. the dash fan will operate the air.
The switch on the center console between the seats(on top of the heater *****) Does nothing!!!!!
lol, I think!
p.s. The a/c only operates in the middle vents.
lol, I think!
mine only goes to three too, but oh well. it took me months to figure it all out but its very simple now.
top row has two *****, right **** is fan speed second **** is freash air, keep right **** on off position and slide left **** up butted aginst right **** to get a little fresh air in, from there just slide the right fan speed **** over to the right more and more for greater fan speed, and as more supply of fresh air is desired, slide the left **** along with it.
next row down i think is whaty controlls the direction in which you want the fresh air to go slide to the right its coming out the defrost vents on top of dash, then slide to the far left and it comes out and blows on your feet. keep in the middel or move around for desired adjustable mix of top or bottom feed.
third row the heat supply, or direction of heat supply. works the same as the 2nd row. to have greater heat out of just those ***** cut off the fresh air supply but keep the fresh air fan speed up and it will blow just heat.
as for the **** inbetween the seats mines been broke for some time now, i need to get a new one
well thats my view on how it works if you couldnt get it from the pic
