Electrical queries
Electrical queries
Hello guys
One of my driving/fog lights,
( under the indicator in front spoiler) is not working.
Had bulb out, and tested it directly across battery, its fine.
The platic connetion plug beside battery, had separated sometime,
but unfortunately it wasen't that simple to fix.
do you know where else I might try and rectify fault
And
where will the rear blower motor power feed wire exit the rear bulhead on its way to the motor
PS,
whats the trick with lens surround on driving light and lining up the
long-thinnnnnnnnnnnn, screws?
And
PS,
Originally Posted by randywebb
check the metal prongs for corrosion & for being bent too far in
Power
I know the bulb is fine and not playing up,
so at that end, just need to replace it around light unit and re-fix it back in mounting on car (bit fiddly)
The coneectors by the battery are slightly corroded as near battery, but theres no power in them at all, so will trace wires back untill there is
Now
as one light works still, are they fused separately too, a quick look at the fuse legend on box cover, mentioned some lights, although their meaning in English might be misconstrued, are the fuses alongside one another numerically in the fuse panel?
Now
