Sticky Winter Throttle
Before attempting to shoot Tri-Flow everywhere, I thought I'd ask to see if anyone knew a common culprit. In the warm seasons my throttle never sticks, but around 0 F. and below it increasingly, intermittently sticks at several points, even after about 100 miles with a fully warmed up engine. It might stick at 3200 RPM or 4000 RPM. I can punch the throttle several times while in 4th or 5th and sometimes it loosens it and sometimes I have to turn the key off and on the roadside work the throttle back and forth manually on the throttle body. Any suggestions?
The Ancient One
Rennlist Lifetime Member
Although this will likely be ZERO help...
I grew up in Anchorage. For a while I drove a VW bug. One winter day the sun was shining brightly (for about 2 hours anyway!) and we decided to do some crazy parking lot/snow drift adventures.
Afterwards, I parked the car outside (as usual) and didn't think about it until it was time to go home that evening.
I was amazed to discover that the clutch tube had ice in it and the cable wouldn't budge. I had to shift by matching RPMs the whole way to home. I finally warmed it up enough to let the cable loose the next day with a propane torch.
I'm wondering if something similar is occurring with your throttle linkage/body.
I'd try applying some type of grease/lubricant to the moving surfaces in order to dispel any moisture that might be collecting (and then freezing) on these parts.
