Door latch removal
I am trying another DIY mod and thought I'd ask before venturing in. Does anyone know how to remove the interior door latches? I can see how the metal arm comes out of the white plastic piece, but how do you remove the bolt that holds the latch?
TIA
TIA
If you are reffering to the interior door handle I just did mine a week ago. There are 2 snap rings on the metal pin that hold the handle in place. You need to remove the top snap ring with a pair of needle nose. It goes back together real easy.
Good luck.
Chad
Good luck.
Chad
