915 drain plug won't budge? Problem Fixed!
I'm trying to drain/change the tran oil in my 915, and the drain plug won't budge an inch. I'm using the proper hex nut/ratchet (17mm), but the darn thing will not move. Any suggestions...are they always this tough to remove?
search here and on Pelican
DO NOT open it or try to w/o getting the fill plug loose first. You posted on Pelican about that, right? If not self-evident yet, just think about what you'll do with a drained trans. you cannot refill.
she's out...what a pain the a**. Leverage is the key (and a little heat). I ended up heating the case a little bit, and let it cool down. Then I used an old torque wrench (much longer handle and stronger than the 3/8 wrench I was using). Now off to replace the oil...
For future use, having a couple of three foot long pieces of galvanized pipe, of sufficient ID to fit over various wrenches/breaker bars really helps. NEVER use those pipes to re-install hardware!
Pete
Pete
Pete, good idea...I feel like an idiot for not using a 1/2 socket wrench in the first place. I just assumed since the hex head I was using fit a 3/8 wrench...that's what I should use. Lesson learned...
Actually I used a 3/8 inch socket as well. I have a 3/8 to 1/2 adaptor and have an old 1/2 inch torch wrench that is now a breaker bar. It works great. I had more of a problem getting the filler plug out first. I could not get enough torch and keep the socket flush. I ended up using a 2 foot long extension so I was turning the plug from outside the rear wheel well. The first hard crank broke it loose and a piece of cake from there on in...
Regards,
Jim,
'86 Coupe
Regards,
Jim,
'86 Coupe
