911 Forum 1964-1989
Headlight wire guage
Old Oct 6, 2005 | 09:45 AM
eldiosyeldiablo's Avatar
eldiosyeldiablo
Question Headlight wire guage
Which guage of wire should I use when back dating my H5s to H4s?
The auto shop guy told me that 16 guage is plenty big. But it looks like the ones in my car may be bigger than that.
Am I immagining things?
Thanks,
David
1988 911 Targa
Old Oct 6, 2005 | 09:08 PM
r911's Avatar
r911
Anti-Cupholder League
they are metric
the imp. thing is to install relays and make sure the connections are all clean
are you unable to use the stock wiring?
Old Oct 6, 2005 | 10:18 PM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
David,
Lots of tech info on lighting given on this site (no affiliation).
I plan to use 12 guage when I upgrade my H5's to H4's and install 80/100 watt bulbs (winter job).
Marc
Old Oct 7, 2005 | 12:58 AM
eldiosyeldiablo
Correct, I am unable to use the H5 connector plug that came with my car for the H4 light bulb.
So I am going to cut some new wires and connect them to the existing wiring harness to allow the next owner of the car to switch back to H5s at a later date.
The current harness uses "Snap" Connectors. I purchased some Snap Connectors from Radio shack that are sized for 16-14 guage wires.
I will still have to cut the original wires but I will replace those connectors with the similar connectors from Radio shack.
Old Oct 7, 2005 | 02:29 AM
r911's Avatar
r911
in that case, use 14 ga.
