Source for OEM speaker grill covers?
If not OEM, then an exact or similar match ? rear deck speaker grilles have cracked over 22 years, have replaced the speakers with Bostons but would like to replace the grilles as well. What's the most likely source for grills ? I apologize for already not checking Pelican or Automotion, but in previous browsing of the catalogs, I don't recall seeing speaker grills.
Thanks!
Thanks!
The Ancient One
Rennlist Lifetime Member
Do a search on here for 'speaker grills'. There is (was) a guy in Texas that made replacement surrounds out of CNC'd aluminum. They are such an exact duplicate of the original plastic parts, that you literally snap the original mesh grills into the new surrounds.
I had mine powder coated black to match the window trim, etc. that I also had done at the same time.
Related question - I also swapped out the original 4 speakers on my 83SC with Boston Acoustics. My original speaker grille surrounds are also cracked. In addition, the new speakers " stick out" of the openings more, not allowing the original grilles to mount flush. I just dropped the new speakers into the existing holes - same way the old ones came out. Should I have mounted them from the inside?
I have had very good luck with getting used OEM parts from PartsHeaven out in California. As long as you did not change the size of the original speakers, PartsHeaven should be able to help.
Here's their website: http://www.partsheaven.com/
The Ancient One
I replaced the original speakers in my 84 as well. I had to mount the rear deck speakers underneath to gain the required clearance for the factory style grills. I was unable to re-use the front grills because hte speakers I chose has the grill 'built-on' as a single unit. They are Polk Audio 5.25s.
I was going to add spacers under the rear grills, but decided that it would detract from the incredible job that was done to make them nearly identical to the originals, thus they were mounted underneath.
BER: Thanks for the partsheaven link, I sent them an email
Dab Cobb - I had no luck with a search for someone that machines aluminum replacement grilles, thanks for the tip though
The Ancient One
Thanks!
Thanks!
![](http://forums.rennlist.com/upload/sc_speaker_grille.jpg)
![](http://forums.rennlist.com/upload/83_speaker_grille.jpg)
Not especially cheap, but it appears you can order them through Pelican here, although you may want to try Sunset Porsche or other cost
plus dealers who frequently have better prices on relatively obscure factory parts.
Good luck,
Tim
I took one of the speakers and a cover to several audio installers and matched up a pair that looked nice. Most shops take the ones they've removed and throw them in a box. The guy at the shop was very nice in helping me and once we found a perfect match, he gave them to me. To me that was kinda rare in todays world.
